I am getting a weird result when running a Purchase Tallied format bill of material and placing it on a drawing. I have tried it with both ACADE 2012 and 2014 with the same result. Some of the rows show the height as if all of the tags are included even though I am not including the tags as part of the report. See the picture below, on the left is what it should look like (an imported Excel spreadsheet) and on the right is what it looks like.
Any one got any ideas on how to fix this? I tried to manually resize the rows, but the table will not let me do it.
Thanks.
Solved by dougmcalexander. Go to Solution.
I have a modified version of the lisp routine pur_pbom.lsp that removes the blanks. The software normally expects tags to be present and, even if you remove the field, the report maintains the space for the tags. It was written that way back in the earliest days of the software. The developer never anticipated that someone wouldn't want to know which components the part number is associated with. IEC typically requires tags on the BOM because they don't usually use balloons to cross reference between panel and BOM. But I agree that tags aren't necessary for a BOM that goes to purchasing.
I'm traveling at the moment and answering you with my phone. When I get a chance I will post the modified lisp file.
That would be awesome Doug! As usual, YOU DA MAN!!
I made sure this issue was logged. I apologize for this inconvenience.
If the user post that Doug supplies works for you, and if you are using AutoCAD Electrical 2015, you can add that user post option to the report's default format .set file (or a specific format file if you are using a specific one). That way it runs automatically any time you run that report saving you from having to run the user post manually.
Pat Murnen
Hi Scott! There are 4 files in the attached zip file. One is the lisp file that supports the creation of a Tallied Purchase List Format Panel BOM, but this one has additional code to allow you to call User Post 3 from the .SET file, which normally removes the Item Column Repeats. This version was also modified by Pat Murnen, to remove the blanks left over when not reporting tags. Open the pur_pbom.lsp file and view with Notepad, if you wish to read the notes at the top of the file, which explain what has been modified.
I have also attached the pur_pbom.dcl (dialog control language) file that works with pur_pbom.lsp. No changes have been made to this file though.
The third file I have attached is my modified pur_pbom.set file which has the line to call for the execution of User Post 3, to be executed from the lisp file. You can rename this file if you wish. You will notice a line in the .SET file that reads as:
User Post Process = 3
HInt: If you ever need to add a User Post Call to your report.set file you can add it to the end of the file. The software might move it to the middle of the file after you click save, as you will see in the attached file. This is normal.
Note: If you are using AutoCAD Electrical release 2015, you do not need to use my modified .SET file. Release 2015 has an option button in the Report Format Setup that allows you to define a User Post to run as part of the report. (see attached screen capture)
Thanks Doug and Pat. We are not using AutoCAD 2015 and will not be for a few years because of compatibility issues with Bentley products that other departments use here.
Trying to set the user post selction in the report format file setup dialog I get the autoCAD warning
can't find _wd_post_setting function
any ideas??
It sounds like you are using an older user post .lsp file. To make the user post work in the format files and run automatically some changes were made to the user post .lsp framework. So you won't be able to use any customized user post files from previous releases. You can most likely copy your custom sections in the older .lsp file to the newer .lsp file. The basic framework is the same in the newer files as far as defining the options. It is a little hard to explain but if you compare the older .lsp files with the 2015 .lsp files you will see the changes made so that it works within a report format .set file.
Pat Murnen
