AutoCAD Electrical General Discussion
Active Member
0 Kudos
Post 1 of 2
BOM Reports Effected by Tags
227 Views, 1 Replies
01-30-2012 06:28 AM
When I create a BOM Report of a panel everything looks correct, but when I create a BOM Report of the entire drawing, it doesn't look the same. Could tags be affecting this?
BSD Technical Support
AdvancedSolutions.com
"You may not be able to erase your past, but you are the artist of your future!"
190 Kudos
Post 2 of 2
Re: BOM Reports Effected by Tags
01-31-2012 10:16 PM in reply to: ASI_BSD
Most obvious question but are you using the same report methods and format.
There may be differences between the schematic and panel reports and the BOM format for each may also be different.
Plus you also have the various types of BOM reports to choose from.
As a test, try to run the two reports again. Make notes on which type of reports, format and so on you are using for the first one. Run the second report using same settings from the first report and see if anything changes.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
