AutoCAD Electrical General Discussion
jmterlap
Message 1 of 2 (150 Views)
BOM on Separate Drawings
150 Views, 1 Replies
01-20-2014 09:15 AM
We currently put BOMs on each drawing that could be assembled separately in our fabrication shop.  For a specific module, this may be one drawing for the operator station, one for the I/O panel and one for the junction box.  This makes it easier for the electricians to know what parts are for specific builds.
I have been able to add BOMs using the panel reports option such that the BOM is located on the drawing. I was able to get the BOM to update by running the panel report again and specify UPDATE EXISTING in the dialog box.
I would prefer to update the BOMs on several drawings at one time.  Is this possible?
I tried to use the Automatic Reports option, but that just added the report to a new drawing.
Thanks for any responses.
*Expert Elite*
rhesusminus
Message 2 of 2 (104 Views)
Re: BOM on Separate Drawings
02-05-2014 04:59 AM in reply to: jmterlap
I have no "real answer" for you, but I somehow think that this would be possible.
The reason for this is that using the Automatic Reports, it will create new drawings the first time, and then update the existing drawings on the next run.
So..
If we could get the Automatic Report functions to just update, without creating the tables first?
I don't have time to explore this right now, but have a look at the Report Format Setup, and see if creating a SET-file with the "update existing" set, will update your existing BOMs.
Take a backup of the project first :smileyvery-happy:
THL
Please select "Accept As Solution" if this post answers your question. Kudos don't hurt either. ;-)
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
