AutoCAD Electrical Forum
BOM on Separate Drawings
1 REPLY 1
441 Views, 1 Reply
We currently put BOMs on each drawing that could be assembled separately in our fabrication shop.  For a specific module, this may be one drawing for the operator station, one for the I/O panel and one for the junction box.  This makes it easier for the electricians to know what parts are for specific builds.
I have been able to add BOMs using the panel reports option such that the BOM is located on the drawing. I was able to get the BOM to update by running the panel report again and specify UPDATE EXISTING in the dialog box.
I would prefer to update the BOMs on several drawings at one time.  Is this possible?
I tried to use the Automatic Reports option, but that just added the report to a new drawing.
Thanks for any responses.
1 REPLY 1
rhesusminus
I have no "real answer" for you, but I somehow think that this would be possible.
The reason for this is that using the Automatic Reports, it will create new drawings the first time, and then update the existing drawings on the next run.
So..
If we could get the Automatic Report functions to just update, without creating the tables first?
I don't have time to explore this right now, but have a look at the Report Format Setup, and see if creating a SET-file with the "update existing" set, will update your existing BOMs.
Take a backup of the project first 😄
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
”Boost
