AutoCAD Electrical Forum
BOM does not update after I have changed a part number.
4 REPLIES 4
electcad
1796 Views, 4 Replies
BOM does not update after I have changed a part number. I have gone into edit and changed an items part number. I then go into the schematic reports and generate the BOM again and when I check the list the item has not updated. The only way I have been getting around this so that it updates, is to close the project and re-open it. Has anyone got an idea of how to solve this problem?
AutoCad Electrical 2014
4 REPLIES 4
OP21
in reply to: electcad
Maybe a few things to try:
1: From the main toolbar/pull down menu: Projects -> Project-> Rebuild/Refresh Project database < Full rebuild > and/or sometimes closing and re-opening the project will solve the issue. - Or -
2: Close electrical, navigate to your "C:\Users\...\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\User" folder and locate the project .mdb file.  Delete it and re-open your Electrical project.  This will re-build the project database.
Hope this may help you in finding a solution....
Omar
If this solves your problem, remember, "kudos" are appreciated...
Hope this helps!
Omar
P.S. If this did help you, remember to "Accept as Solution", so the answer can help others. "LIKES" are always welcomed and much appreciated! Thank-you.
electcad
in reply to: OP21
Thanks Omar
The project rebuild option worked.
Regards
Chris
dougmcalexander
in reply to: OP21
Omar, you are so right!  I add the Rebuild/Freshen Command back to the ribbon menu and teach how in every class I teach, because it is so very necessary for many functions of the software. It should have been put on the ribbon menu.
There are often lags before the database manager can catch up to the drawing edits.  This can be devastating when you generate a report, only to find out from your panel shop later that parts are missing or incorrect.  Be especially careful when building subassemblies via the Multiple Catalog list.  If you a subassembly assignment via Multiple Catalog on the schematic component symbol, verify that the change was actually written to the related footprint symbol.  If you create your BOM from the panel layout, to ensure that the enclosure, DIN rail, wire duct, etc. appear in the BOM, your panel BOM might have inaccuracies.
I use the CUI editor to add it between Update/Retag and Utilities (see attached).  After you add it to the menu, be sure to edit the settings as shown in the attachment, so the icon appears large with the text below it.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
electcad
in reply to: dougmcalexander
Thanks Doug
I have added the Rebuild Freshen Database to my custom ribbon as suggested.
Regards
Chris
Australia
”Boost
