My problem is different. Here is a better explanation and a test I just ran.
1/ Project was created in AutoCAD Electrical 2006 from a 2005 project using
"Copy Project".
2/ Drawing has 16 motor starters that all have part numbers (from
default_cat.mdb).
3/ Purge the drawing.
4 Run "Schematic Report, BOM, Active drawing" . Report Generator shows the
16 starters (on the screen).
5/ Close Schematic report.
6/ Add two more starters on the sheet using "Copy Component"
7/ Verify that added parts have the same BOM data and "Location Code".
8/ Run "Schematic Report, BOM, Active drawing" . Report Generator still
shows 16 starters (on the screen). New parts are not picked up.
9/ Run "rebuild database file".
10/ Run "Schematic Report, BOM, Active drawing" . Report Generator still
shows 16 starters (on the screen). New parts are still not picked up.
11/ Close AutoCAD .
12/ Delete project mdb from "D:\Documents and Settings\e329022\Application
Data\Autodesk\AutoCAD Electrical 2006\R16.2\enu\Support\User"
13/ Open AutoCAD and run "Schematic Report, BOM, Active drawing" . Report
Generator now shows the added starters (on the screen).
"TStewart"
wrote in message news:5072698@discussion.autodesk.com...
When I add parts to a drawing with BOM data, the .mdb file does not appear
to be updating. I run a BOM for the sheet and the parts do not appear, yet
they are on the drawing and have BOM data associated with them. I have run
the rebuild file data base utility several times with no success. The
drawings and the .mdb are on my local PC.
