AcadE has two concepts for inserting schematic stuff, 1) block symbols, and
2) circuits. It sounds like what you want to do is insert a "circuit" that
consists of some interconnected blocks, wires, and such. When AcadE inserts
a circuit, it pops it in and explodes it, then moves the LINES it finds to
wire layers (if not already on a wire layer) and retags the parent
components in the circuit and updates any related child contacts in the
circuit.
The product ships with a handful of sample motor starter circuits. Try
popping one of these in and you can get an idea of what AcadE can do with
this idea. Go to the on-line Electrical Help and select the "Search" tab and
type in "Circuit". It should get you pointed in the right direction.
Nate.
wrote in message news:5496977@discussion.autodesk.com...
I'm new at this and to AutoCAD Electrical... I've been playing with it some
and I have run into things that I would like help with... I have created
several blocks, now I'm trying to create a block out of several blocks. The
thing is that the wire that is attached to these components will be part of
the block.(ex. I have a three line diagram and I have a 3phase ct and the
wire runs to a terminal block.. the wire that connects the two needs a wire
# and if I make this a block, AutoCAD does not recognize it as a wire but a
block.. so how can I make this work any suggestions would be very
appreciated.
