I have a block in my drawing where the description attribute is to the left of the block and now I want to move the description attribute to the bottom of the block instead. I editted the block's dwg (was created with wblock) so that the description attribute is on the bottom of the block. After editing the block's dwg file, I went back to the original drawing where the block resides but the description attribute is still to the left of block. If I insert a new instance of the block, the description will be on the bottom of the block which is what I wanted.
What is the command to update the block so that the attribute moves to the bottom of the block?
Also when I'm in the block editor, where can I go to see the block's name? Is the block's name the same as the dwg name that it resides in?
This command worked perfectly except the command is "ATTSYNC" not attsinc. This solution worked where as the "Sync" button on the Block Attribute Manager did not work. Thanks
