AutoCAD Electrical General Discussion
Valued Contributor
0 Kudos
Post 1 of 2
Block not found
89 Views, 1 Replies
11-21-2003 12:08 AM
I am trying to insert a wire color, and
the block is not found in any of the libraries
by Electrical. When I check my library, it's right
there! I made sure the zero was not an "Oh", and I
know I am going to the correct library. I can
insert a standard color label, like RED, but
when I try "You Type", none of the three blocks
is found.
I've used these blocks before without problem.
What could be happening?
Lynne
Valued Contributor
0 Kudos
Post 2 of 2
Re: Block not found
11-21-2003 02:54 AM in reply to: Lint
I closed down my program and restarted it and
this problem went away!
Lynne
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
