AutoCAD Electrical Forum
Block _dum1 references itself
2 REPLIES 2
laki.anu87
641 Views, 2 Replies
When I am trying to insert a circuit using circuit builder, only power circuit is getting inserted but not control circuit. Following error message is shown in "command line".
2:44 PM
inserting cross-references
reading project database file . . .Block _dum1 references itself
Retrieving project wire numbers in use .
 2:44 PM
How do I solve this issue. I need the control circuit to be inserted.
2 REPLIES 2
laki.anu87
in reply to: laki.anu87
Icemanau
Can you insert the block DUM1 by itself or does it come up with the same error?
If it comes up with the same error, then that means the block itself is faulty. This usually happens when the block is saved with a copy of itself within the same file.
Try to open the block and then explode everything inside it. Next 'Purge All' the dwg and get rid any extra layers, fonts and whatnot.
If you can't open the block, you may need to recreate the block from scratch.
Regards Brad
Brad Coleman, Electrical Draftsman
”Boost
