AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
black box tag1
11 REPLIES 11
Message 1 of 12
287 Views, 11 Replies
black box tag1
I make a balck box today, n i insert all attribute like tag1 arrtibute1 familly code ect
but if i put my block 2 time on the same lader the tag1is suppose to be automaticaly incriment Ex: pb1a, pb1b, pb1c.
it s working if i but an origninal block but not whit the one i made can someone help me plz
11 REPLIES 11
Message 2 of 12
Can you attach a copy of your symbol ".dwg" file to your message so I can
look at it ?
wrote in message news:5097068@discussion.autodesk.com...
familly code ect
someone help me plz
Message 3 of 12
i just explode an original push buton n i did a black box whit all the original tag n when i try tu put more than 1 in a ladder the same thing happen, they keep the same name
Message 4 of 12
I tried the attached symbol and it seems to work fine. I use the normal
Insert Component command and enter in the path/name of your symbol in the
edit box in the bottom left-hand part of the icon menu. I tried it on demo04
drawing of the WDDEMO sample project. Each time I insert it, it gets a new
tag-ID based upon its position along the ladder's line references.
Maybe you can attach the drawing showing your ladder and several inserts of
this symbol?
Nate.
wrote in message news:5097111@discussion.autodesk.com...
Message 5 of 12
do i have to save the wblock at a specific place.
Message 6 of 12
OK i thik i have a part of the problem it s because when i save a black box im saving it on a server caus i want to share it whit the other user. but my JIC lib are locate in my pc.
do i have to save the block in the jic library and if yes how can i share it.
Message 7 of 12
You merely have to add the path(s) to your custom files to the project library path. Right-click on the project in Project Manager and select Symbol Libraries. Add your path(s) in front of what is there, seperating each path with a semicolon (;).
-Steve
Message 8 of 12
i just try this n it s not working
after it i try to save my block in the jic125 lib, n it s not working more
Message 9 of 12
dougmcalexander
I believe your block name is the problem. ACADE keys off the block name. Rename your block to V_N1_SSR1 and all should work. I have similar SSR's. I design to IEC standards. The N is the proper designator for an SSR within the IEC. If you prefer the tag to be SSR that's fine. The important thing to know about naming blocks is that the first character needs to be "H", indicating wires coming in horizontally, or "V" for wires coming in vertically. If you have a symbol with wires connecting both vertically and horizontally, use "H". The next two characters indicate the family of the component. You must use only two letters. For example "SS" for selector switch, "CR" for control relay. You cannot use 3 letters for the family type. Since the IEC normally uses single character tags (i.e. "S" for switch, "Q" for circuit breaker, "G" for power supply) insert an underscore "_" as a placeholder in the 3rd position of the name. The last position of the block name should be "1" for parent/stand-alone or "2" for a child. For example a relay coil is a parent and a relay contact is a child. Use "1"for components that have no children.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Message 10 of 12
dougmcalexander
Clarification: In the block name VN_1_SSR1 everything past the 4th character is optional. You could put the part number or anything you wish that would make the block memorable to you.
Doug McAlexander
Message 11 of 12
thx i will try this
Message 12 of 12
thx a lot its working verry well
”Boost
