I have created a component with the black box builder and put it on the component picker dialog with the icon menu wizard. The part has three terminals on the left, three terminals on the right and eight terminals across the bottom. The problem I'm having is when I insert this component on a three phase wire it rotates the block 90 degrees. Is there a special procedure to create components for three phase circuit insertion?
