Mask_Man
It looks like it is due to the block name you assigned. If you follow
the block naming convention for AutoCAD Electrical (Symbol Builder supplies
a default name following this convention automatically, you can change after
the "_" to anything you like, preceeding the "_" follows the naming
convention), the wire numbers assign correctly. For example, I renamed the
block to "HPS1_MYPOWERSUPPLY.dwg" and the each wire connection point was
assinged a unique wire number, just as you would expect.
I hope this helps!!
Jared Bunch
Product Designer
AutoCAD Electrical
Autodesk, Inc.
Check out the Manufacturing Community at:
http://mfgcommunity.autodesk.com/
wrote in message news:5794820@discussion.autodesk.com...
The block is attached. Thanks for the help.
