AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Bill of materials - wires/cables in Autocad Electrical
4 REPLIES 4
ionescu.bogdan.g
1820 Views, 4 Replies
Is there any way to assign lengths to cables and to create an automated BOM which contains all types of wire used ( AWG + color ) and the relative total length?
Thanks in advance
4 REPLIES 4
There is no inherent functionality to support this.  There is a field named CLEN (short for calculated length) which can be added to your wire from/to list report and the lengths, if known, can be typed into this field using Edit Mode from the report dialog. (see attached screen capture)
I wrote an external MS Access database application that allows me to import the from/to list and perform calculations of total amount of wire needed for each wire type.  I also added fields for defining the type of termination device (i.e. ring, spade, ferrule, etc.).
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
Thank you for your answer.
Not to abuse your patience but can you please also tell me How to change CLEN for a wire in the schematic?
I am trying to do right click -> Change/convert wire type. I see Used, wire type, size, layer name, wire numbering and some user fields. How do I get to change CLEN?
I am using autocad electrical 2012 and I'm relatively new.
So if I understand right I do this : define clen for each wire (or atleast each wire that counts), make a from/to report including clen field. After this can't I just export it to excel and make the calculations in excel ? I just need total amount of cable of each type ( ie 1000m yellow 1.5mm^2 ; 500m blue 6mm^2 ...)
Thanks again
I managed to change the CLEN from the Report Edit, but it gets lost. I create a report, I put in length, save it. When I try to create another report (something changed) I have to fill all CLEN again.
Is there any solution to this?
CLEN is only a field that can be added to a report as a place for you to type in wire length. The data is not stored anywhere other than in the report itself, when you print it or insert as a table on a drawing, or save as a spreadsheet. You can rename CLEN to something like Wire Length after you add it to your report, the same as how you rename any of the other fields in a report.
Doug McAlexander
”Boost
