AutoCAD Electrical General Discussion
Member
motorthings
Message 1 of 13 (144 Views)
Best Practices for Symbol Libraries, Updates, and Custom Symbols?
144 Views, 12 Replies
02-22-2007 12:40 PM
We just implemented AutoCAD Electrical 2007 and I am looking for ideas of best practices to manage symbol libraries.
We plan on using the standard symbols installed on each user's workstation for the majority of our work, but sometimes the designers will need to create a custom symbol. What is the best way to manage those custom symbols so all users have access to them?
Also, I have been told that Autodesk sends out updates to the symbol library. I figured i would just take those updates and copy them to all of the users' symbol libraries on their harddrives. Is that the common practice?
Thanks in advance!
*Expert Elite*
dougmcalexander
Message 2 of 13 (144 Views)
Re: Best Practices for Symbol Libraries, Updates, and Custom Symbols?
02-22-2007 11:02 PM in reply to: motorthings
Create a library folder on your network, for example, UserLib. Go to your wd.env file (usually in your My Documents\Acade 2007\AeData\ folder). Edit this wd.env file with Wordpad or Notepad and look for a line that reads:
*WD_INSCOMPDLG,x:/some path/,to override starting path for INS SCHEM COMP browse button
Remove the asterisk and edit the path statement to read your network path to your UserLib.
When you Create new symbols or click Browse from the Insert Component menu, the default path will be UserLib. You can copy symbols from the JIC1, JIC125, IEC2, or IEC4 folder to UserLib and edit them to your choosing. Just be sure to keep the file name the same. Right-click on your Project name and select Properties. Add the network path to UserLib to your library list. Move it to the top. When you click to insert a standard symbol from AutoCAD Electrical, the one in your UserLib will get priority.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
Member
motorthings
Message 3 of 13 (144 Views)
02-23-2007 05:53 AM in reply to: motorthings
great! thanks for the info.
should i also edit the line below that in the wd.env to point to a folder for what looks like the panel components library folder?
i assume this is another default folder holding a different set of symbols that are used in panel design...
*Michael Trull
Message 4 of 13 (144 Views)
02-23-2007 08:22 AM in reply to: motorthings
Our situation is similar in that each user wants their libraries local. This
is because they are using notebook computers and they need their libraries
available when they are remote and not connected to the network.
Unfortunately, a common shared location on the network would be unavailable
any time they are working remotely and therefore unacceptable to them.
Has anyone developed a good solution for notebook computers who will
frequently be disconnected from the network?
Thanks in advance for your help!
Sincerely,
Michael
Distinguished Contributor
doctatrips
Message 5 of 13 (144 Views)
02-27-2007 05:12 AM in reply to: motorthings
What we do is to store all of our custom libraries, symbols, toolbars, templates, etc. on the server. Then create a batch file that runs automatically everytime someone logs in and it can be run manually as well. This batch file maps all the specified data from the server and brings it to that users local drive.
This has addressed the issues of people using notebooks and also has reduced the traffic on the server.
karendsen
Message 6 of 13 (144 Views)
02-28-2007 03:26 AM in reply to: motorthings
I was wondering how we are going to handle this at my company. Do you mind e-mailing that batch file for an example? Is it specific to ACE? Sounds like it could be useful to us. Especially since we end up doing updates to prints while on site at our customer.
karendsen@alltech-eng.com
Kyle
Active Contributor
krollenhagen
Message 7 of 13 (144 Views)
02-28-2007 04:59 AM in reply to: motorthings
I use a program called SmartSyncPro to take care of synchronizing all files between my laptop and the server. I believe it costs $20.
doctatrips
Message 8 of 13 (144 Views)
02-28-2007 05:23 AM in reply to: motorthings
Here is a copy of the batch file that we used in ACE2006. Obviously you will need to tweak things for 2007.
To make it a batch file you will need to save it as *.bat. I had to to attach it as a *.txt as batch file types cannot be attached.
*Michael Trull
Message 9 of 13 (144 Views)
03-01-2007 02:47 PM in reply to: motorthings
Thank you for your comments.
Synchronizing with a network location seems to be the best solution. We will
need it to be bi-directional though. I want to be sure any new content
created locally is added to the server location without someone having to
remember to do it.
Are you also using Vault? If so, do you check the server files into the
vault so that all of your data is vaulted?
Sincerely,
Michael
wrote in message news:5502857@discussion.autodesk.com...
Valued Contributor
Elect74
Message 10 of 13 (144 Views)
03-01-2007 04:59 PM in reply to: motorthings
While I haven't used it, others have recommended to me a software called FolderShare that keeps two directories synchronized.
Let me know if it works for you.
Announcements
Manufacturing Community
The Manufacturing Community provides additional access to tips, tutorials, blogs and networking with peers.
Need installation help?
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
