AutoCAD Electrical General Discussion
Valued Contributor
rwydesk500
Message 1 of 3 (440 Views)
Batch Scripting Drawings in AutoCAD Electrical
440 Views, 2 Replies
06-01-2012 04:23 AM
Is it actually possible to run any script on a batch of drawings (as long as they are in the same project)?
I've been looking for AutoDesk to add this feature to AutoCAD for years!
If true, then is it possible to "Add Drawings..." in the Project Manager (like drawings created in only AutoCAD), and then run a script on them via the Project-wide Utilities feature?
I'm about to try it, but I don't want to screw anything up...
Rick Yoerger
AutoCAD Electrical 2014
testsubject
Message 2 of 3 (437 Views)
Re: Batch Scripting Drawings in AutoCAD Electrical
06-01-2012 05:54 AM in reply to: rwydesk500
Rick,
Any DWG can be in the project; not just  Autocad Electrical drawings. It is a common practice of mine to include plain AutoCAD drawings into the project and mark them as reference. If you use an ACE enabled titleblock in them, you can also change the titleblock of these drawings.
Bob Hanrahan
Ace User since 1998
Valued Contributor
rwydesk500
Message 3 of 3 (381 Views)
08-28-2012 04:51 AM in reply to: testsubject
BTW - Batch scripting changes to drawings seems to be working beautifully. All you need to do is write a script that works for one drawing, then apply it to a whole set of drawings in the Project Manager. Awesome!
Rick Yoerger
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
