AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Batch Plotting not completing request
1 REPLY 1
248 Views, 1 Reply
hey everyone;
I've been trying to batch plot a series of drawings to an ethernet printer, anything between 10 and 100 dwgs in AutoCad Electrical, and it will not process past four or five drawings.
I've noticed in the past that if I have all drawings in a project file opened then tried batch plotting them, it works fine, but if only one of the drawings are opened, it will only process a couple of the dwgs.
Is this supposed to happen like this or is AutoCad getting hung up on something?
1 REPLY 1
pmccutcheon
I'd say hung up.
Sometimes if the plotting hasn't already been setup for a particular sheet it will stop.
i.e. if you have single plotted at some point sucessfully each sheet, then usually the mult-plot will work
conversely, if the 5th sheet doesn't have plotter set properly, it might pause/stop when it gets to that sheet
?what version of AE?
”Boost
