Being a new user, from habit, I press delete when removing objects when I mean to use delete component. If there is a way to force a popup when Delete is pressed that I could turn on to help me break that habit, it would be very helpful.
Welcome to the forums.
Note that some of these forums have a sub forum called Idea Station which is where you put your ideas for features or fixes for software. Obviously this one does not. For feature wishes and ideas where there is no Idea Station... post here to get it to the development team.
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
No idea, but that is a good question. I hadn't considered that until I saw a new employee deleting stuff that way. We've pretty much grown up on the Command>Select>Execute way of doing things so highlighting/selecting objects and hitting the delete key wasn't on my radar.
Have you looked in the CUI? Not sure that would be there though as I think it is a system level function, not a command per se.
