AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
Balloon inserts exloded
4 REPLIES 4
testsubject
270 Views, 4 Replies
I know this is a simple setting (having come across it years ago) but for the life of me I cannot remember it and I just spent an hour searching for it. When selecting a item balloon, the whole thing is broken into pieces when it should act as one piece. Anyone remember the setting?
Robert Hanrahan
Bob Hanrahan
Ace User since 1998
If this answered your question, please click on "Accept Solution"
4 REPLIES 4
JeffatSJE
in reply to: testsubject
PICKSTYLE works with groups I'm not sure about blocks.
I would realy like to see ACE use leader objects when building the balloons.
testsubject
PICKSTYLES was not it. I remember that it was a swtich that did it (ie, set either 1 or 0).
Bump
Bob Hanrahan
Ace User since 1998
Balloons are inserted as a block and then some
individual entities to make up the leader. These are grouped together. The
PICKSTYLE setting determines whether groups are on or off. You can also press
Ctrl+Shift+A to switch between groups on or off. If this isn't it then you might
post a drawing with a balloon on it so someone can look at it.
Pat Murnen
PICKSTYLES
0). Bump
testsubject
Thanks, Pat!
That was exactly what I was looking for. I knew it was a simple switch but could not remember what it was.
Bob
Bob Hanrahan
Ace User since 1998
”Boost
