I am assuming you have the %S in your cross-referencing format. This value
comes from the Sheet value held in the Drawing Properties (Drawing Config in
2006) held in each drawing. So this Sheet value would need to be input for
each drawing or this can be done quickly on a project using the Title Block
utility and selecting the "Resequence sheet %S values" option.
Pat Murnen
wrote in message news:5135437@discussion.autodesk.com...
When I test my intelligent template, I insert elements on two saved drawing,
the Contact Cross-Referencing indicate sheet 1 permanently.
From where could this small problem come?
Thank you for your assistance.
