AutoCAD Electrical Forum
Automaticly generate my electrical schema from .xls data
2 REPLIES 2
614 Views, 2 Replies
Hello eveyone,
I am new in Autocad Electrical 2013 and i am trying to automatism my work.
After a quick look on the others topics i do not found the answers of my problem.
I have thought of first create a base for my entire project in .dwt
Then realize different .dwg like a library
The last thing is using VBA and a excel sheet to import only the items i need.
My questions are : Is it the good way to do ?
                               Is someone able to tell me how i can import in a .dwg another one like a block (in VBA) ?
I have tried this :
Sub Test_Insert()
Dim pts(0 To 2) As Double
pts(0) = 20: pts(1) = 20: pts(2) = 0
ThisDrawing.Blocks.Add(pts,"C:\path\file1.dwg")
End Sub
Of course it is not working 🙂
If someone can help, having example or answer or anything else which can help, I will be great full.
Thanks by advance
Regards
Nicolas
Ps: Sry for my frenchy English
2 REPLIES 2
rhesusminus
To answer your VBA-question.
You are trying to add a new block to the drawings block-library.
To insert a block into a drawing (creating a block reference), try this code:
Sub Test_Insert()
ThisDrawing.ModelSpace.InsertBlock pts, "C:\path\file1.dwg", 1, 1, 1, 0
End Sub
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
in reply to: rhesusminus
Spoiler
Thanks a lot, I have tried your cod and it is working well!
”Boost
