AutoCAD Electrical Forum
Automatic wire tagging not tagging all wires?
2 REPLIES 2
8c
560 Views, 2 Replies
Hello
I'm fairly new to autodesk, I have tried the drawing wide auto wire tag and it doesn't seem to be tagging all of the wires any suggestions from you guys why it might be doing this?
Any help appreciated
Cheers
Peter
2 REPLIES 2
dougmcalexander
in reply to: 8c
Be sure that the terminal block symbols on those un-numbered wires are of the type to force a wire number change. It appears that you prefer to assign a different wire number to field wires. You must force the wire number change by using a terminal or connector that changes the wire number as it passes through. Hint: This type of terminal or connector must also be used if your field wires are set for no wire numbering.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in AutoCAD Electrical training and implementation support
Phone and Web-based Support Plans Available
Phone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please Accept as Solution if I helped you. Likes are also much appreciated.
in reply to: 8c
Also check that your wire layers are able to be numbered. Type AEWIRETYPE in ther command line and make sure that the wire numbering box for the wire layer that you are trying number has "YES" in it.
”Boost
