AutoCAD Electrical Forum
Automatic Reports Panel Nameplate Autocad Electrical 2013
1 REPLY 1
cjpeach2000
846 Views, 1 Reply
Hi all,
Does anybody know if you can add the "Panel Nameplate" into the automatic reports? the only ones that appear are Bill Of Materials and components.
Basically we have multiple door layouts with different installations and locations and want to give our engraving department a list of "Everything", i know this can be done one by one then append the output files but this takes time and it seems silly no to be able to do this in one hit.
Any ideas would be much appreciated
cheers in advance
Chris
1 REPLY 1
psrajesh4u
in reply to: cjpeach2000
When creating a panel lay out name plates can be inserted. After that if we are generating reports for panel then only you will get the total bom for a panel including din rail, name plate, enclosures etc. Using the report format set up you can use the descriptions 1,2,3 add in to report and give to engraving section with name plates standards as type A, type B, type C etc.
regards,
Rajesh.
”Boost
