AutoCAD Electrical General Discussion
New Member
0 Kudos
Post 1 of 4
AutoCadElec 2010 Terminal issue
330 Views, 3 Replies
09-08-2009 10:48 AM
In 2090, when I inserted a terminal strip using the TSE, the center wire number (wireno tag on the footprint) was supressed. Only a %W would show the wire left and wire right numbers (wirenol and wirenor respectively). The center of the terminal showed only the terminal number (I use the HT0002 terminal).
We've upgraded to 2010, and now the TSE populates the center wire number. So, my terminal number is covered up by wire number. And it does this regardless if the %W was entered or not.
Question: Is there a "fix" or a menu option that will supress the wireno on the foot prints without having to go through and edit every single terminal in the catalog?
Why does 2010 populate that attribute and 2009 didn't?
Thanks for your help.
Lawrence
291 Kudos
Post 2 of 4
Re: AutoCadElec 2010 Terminal issue
07-23-2010 08:53 PM in reply to: LWareham
Would someone at Autodesk care to answer this? I have seen the same issue in version 2010 and 2011. It's annoying!
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
0 Kudos
Post 3 of 4
10-14-2011 11:28 AM in reply to: LWareham
Yes, it is VERY annoying.
Please fix.
Jim
191 Kudos
Post 4 of 4
10-16-2011 03:20 PM in reply to: robotman2
Quick and dirty fix....
Get the block name of the offending footprint, find the dwg for the block and open. Select the attribute and go to the properties for it. Find the Visibility option (Called Invisible in 2008) and set it to hide the attribute.
Now do a block update and your problem should be solved.
Regards Brad
Icemanau (NNTP handle: Brad Coleman)
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
