AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
AutoCAD Settings
1 REPLY 1
kenangun
265 Views, 1 Reply
AutoCAD Settings
Our customers have told us that the problem in this way. We're waiting for your answer about the cause of the problem
Thank you for your attention.
AutoCAD 2014 also frequently have a problem that happens to us would be glad if you can help. We've developed some lisp in the company, fonts, fonts, fonts and layouts title to the share on the file server have gathered in a public place. After installation of AutoCAD Options \ Files Support File Search Patch portion portion portion and the Trusted locations are entering this individual ways of sharing. Also from the System tab, enter the Executable File Setting section, select Load from only the Trusted locations are marked. After that, without the inconvenience of trying everything. When you turn the computer off and we are going to all of these adjustments, and we are forced to do it again. So far in older versions (2012 and 2013) have not had such a problem how do we fix it?
1 REPLY 1
jalger
in reply to: kenangun
Hi Kenangun,
Check if its the profiles causing the issue, or if its the user account.
Try creating a new AutoCAD Profile.
Make the changes in the new profile. ( add the trusted locations)
Next tie the new profile to the shortcut of the Product.
Right click on the shortcut, go to "properties".
Find the Target section, change the "/P <<ACADE>>" portion of the target to the name of the new profile.
Now open AutoCAD and see if the new profile is resetting or if the changes are staying.
I hope this helps,
James
James Alger
(I'm on several hundred posts as "algerj")
Work:
Dell Precision 5530 (Xeon E 2176M)
1tb SSD, 64GB RAM
Nvidia Quadro P2000, Win10
”Boost
