AutoCAD Electrical Forum
Welcome to Autodesk’s AutoCAD Electrical Forums. Share your knowledge, ask questions, and explore popular AutoCAD Electrical topics.
AutoCAD Electrical wire number spacing
1 REPLY 1
kghew01
290 Views, 1 Reply
ACADE 2012 : When inserting wire number, using WD_WNH block with defined vertical distance from origin, number sits much further up from wire than distance set in block.
Block update confirms that it is the correct block & path, and moves number to the correct vertical offset. Any new numbers inserted then need a block update again. Also happens with wire number copy using _WCH block, and again, block update fixes it.
This happens in new purged drawings as well as already populated ones. Have tried excluding all other paths and instances of WD_WNH, and played extensively with project / drawing properties and DIMSTYLE.
Not a show-stopper, just annoying. Any ideas, anyone ?
Keith
1 REPLY 1
I can't reproduce the issue in my side, can you provide a detail steps for this issue, or a video will be perfect.
If needed, you can send the video to this email: zhonghua.shou@autodesk.com
Thank you very much for reporting issues for AutoCAD Electrical!
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
”Boost
