I have AutoCAD Electrical 2010, is there a way to update the Panels Icon menu Library? Also is there any way to add Icons to this menu as well or are we limited to Changes only in the Schematic Icon menu? Thanks in advance
Solved by drathak. Go to Solution.
@Anonymous wrote:I have AutoCAD Electrical 2010, is there a way to update the Panels Icon menu Library? Also is there any way to add Icons to this menu as well or are we limited to Changes only in the Schematic Icon menu? Thanks in advance
It can be edited in a similar manner to the Schematic menu. I don't have access to 2010, but in 2013 when you launch the Icon Menu Wizard you are first prompted with the dialog box shown below. Clicking on the "Panel" button loads the path to the panel menu into the field at the top. From there you hit ok and rock on as usual. Hope this helps. (Of course you can browse to it too.)
