AutoCAD Electrical Forum
Autocad Electrical P&ID functionality
2 REPLIES 2
leehunt
779 Views, 2 Replies
Can the P&ID symbols be resized without destroying the blocks and maintaining the integrity of all the attributes and the general look and feel of the symbol?
2 REPLIES 2
Icemanau
in reply to: leehunt
For single instances, you can scale the blocks on insert or after, just like the normal electrical blocks.
If you go to Components->Symbol Library->Modify Symbol Library you can pick appropriate library and scale all the blocks as well as change fonts, attribute size and so on. Just be aware that this will take a fair while and involves opening each block and making the changes as required. It is probably best to run this command overnight or even over then weekend so as to not confilct with trying to work on dwgs.
Regards Brad
Brad Coleman, Electrical Draftsman
KevinLi-Autodesk
It can be scaled schematic or panel symbol during insertion, see attached image.
Kevin Li
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
”Boost
