Hi, I have installed the Autocad Electrical 2015 student edition software and I have a problem with inserting symbols. I have changed to iec library but whenever i try to insert any symbol it sends me a mesage like this:
Did I steup something wrong or is it an autocad problem? I guess I did something wrog. Any help would be great.
this is something where paths in the options are not set for libraries that are required to use for a particular setting. Use following to set right paths for your standards
Type "Option" command
Goto "Files" Tab
Add necessary file path locations of your libraries under "Support File Search path" & "Working Support File search Path" section.
