AutoCAD Electrical is not database-driven, but drawing-driven. All drawing data is stored in the DWG file for each drawing, not in an external database that must be polled each time you open a project. The project "scratch" database is used to expedite functions while designing, editing, and generating reports. This database is comparable to RAM in a computer. It is created automatically when a project is created. It can be deleted at any time. If you re-open a project for editing or revisions AcadE will create a fresh "scratch" database for the project. The database is named for the project name. It is stored in the User folder and is in Microsoft Access format. You can view its contents with MS Access 2000 or later. To see an example, look in the User folder for a database named WDDEMO.mdb or IECDEMO.mdb. These are the scratch databases for the demo programs that install with the software.
Note: If you have a project open for editing, you cannot delete the database. There will be a lock file present. Exit AutoCAD Electrical to release the lock.
Doug McAlexander
Design Engineer/Consultant/Instructor/Mentor specializing in
AutoCAD Electrical training and implementation support
Phone and
Web-based Support Plans AvailablePhone: (770) 841-8009
www.linkedin.com/in/doug-mcalexander-1a77623
Please
Accept as Solution if I helped you.
Likes are also much appreciated.
