AutoCAD Electrical General Discussion
Member
amason88
Message 1 of 8 (1,530 Views)
AutoCAD Electrical, Contractor Symbol ?
1530 Views, 7 Replies
02-22-2013 04:01 AM
Hi All,
Ive been searching the net for this for hours now and im just wondering if im being stupid in thinking there is a AutoCAD Electrical symbol for a 3 phase contactor or do you have to put 3 seperate contacts in and parent them to a contactor coil?
I'm running AutoCAD Electrical 2011.
I hope im not being stupid and the anwser is in front of me.
If anyone can help ive appreciate it.
Nata_ly
Message 2 of 8 (1,526 Views)
Re: AutoCAD Electrical, Contractor Symbol ?
02-22-2013 04:26 AM in reply to: amason88
Hi!
Is it in a Motor Control menu?
Member
amason88
Message 3 of 8 (1,522 Views)
02-22-2013 04:44 AM in reply to: Nata_ly
There's one called motor start 3 pole, but i was always led to believe it was a different symbol than the one shown on that?
dougmcalexander
Message 4 of 8 (1,506 Views)
02-22-2013 05:26 AM in reply to: amason88
Contactors and motor starters are used interchangeably.
Doug McAlexander
Independent Consultant/Instructor/Mentor specializing in AutoCAD Electrical, ecscad, and promis-e implementation
Web site: www.ECADConsultant.com
Phone: (770) 841-8009
Please Accept as Solution if I helped you. Kudos are also much appreciated.
testsubject
Message 5 of 8 (1,504 Views)
02-22-2013 05:28 AM in reply to: amason88
That is the one to use for a motor contactor (3 Phase Starter Contacts NO). It is built dynamically from 3 NO/ contacts (HMS21) and then joined with a link line.Then you add the Starter coil as a parent and link it to the contacts.
Bob Hanrahan
Ace User since 1998
Member
amason88
Message 6 of 8 (1,500 Views)
02-22-2013 05:39 AM in reply to: testsubject
Thanks alot guys, im all sorted now.
Cheers :smileyhappy:
Active Contributor
RePao
Message 7 of 8 (1,467 Views)
02-24-2013 04:26 AM in reply to: amason88
We are working with AutoCAD ecscad in D-A-CH and there of course exist symbols like MAINCONTAKTS with 3 NO in one Block. I'am not really sure, but I mean that in electrical you can only place 3 single NO to one, (hide DID and so on, will be useful) Regards Ren?
stay tuned &
Greetings from Switzerland
dougmcalexander
Message 8 of 8 (1,450 Views)
02-25-2013 05:20 AM in reply to: RePao
I use ecscad and AutoCAD Electrical.  The difference is that with ecscad, just like all other electrical CAD software, you must create a symbol for 1 contact, 2 contact, 3 contact, etc.  AutoCAD Electrical builds the contacts dynamically by inserting multiple 1 pole contacts and combining them with a dashed link line to indicate they are activated together by the same coil, button, or selector. This method allows the software to insert the symbol across any wire spacing.  If you wish to add a 4th contact, go to the menu for that type of symbol and look for a 2nd+ or 2+ type of symbol.  This is used to add additional contacts to an existing symbol.
Doug McAlexander
Manufacturing Community
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
