AutoCAD Electrical General Discussion
0 Kudos
Post 1 of 3
AutoCad Electrical and PDM
266 Views, 2 Replies
10-03-2003 12:16 AM
Is anyone aware of the best way to utilize a PDM System with AutoCAD Electrical. Should we be checking out all of the drawings in a project or just one at a time. Any help on this would be greatly appreciated.
*Holt, Nate
Post 2 of 3
Re: AutoCad Electrical and PDM
10-03-2003 09:38 AM in reply to: rstein546
AutoCAD Electrical 2004 uses a "project" concept to
pull together a collection of one to hundreds of interrelated schematic, panel,
wiring diagram drawings together. Each project is given a name and is
represented by a small ascii text file that lists all of the different AutoCAD
drawings that are to be treated as a single project set for component
tagging, cross-referencing, wire numbering, and BOM report generation.
For these inter-drawing functions to fully work,
AutoCAD Electrical needs to be able to access the complete drawing set.
Therefore, with a PDM system, instead of checking out individual
drawing documents, you would probably want to check out a project
set.
0 Kudos
Post 3 of 3
Re:
10-04-2003 10:22 AM in reply to: rstein546
Thanks Nate, That is what I thought. Just wanted to verify.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
