AutoCAD Electrical Forum
AutoCad Electrical and PDM
2 REPLIES 2
858 Views, 2 Replies
Is anyone aware of the best way to utilize a PDM System with AutoCAD Electrical. Should we be checking out all of the drawings in a project or just one at a time. Any help on this would be greatly appreciated.
2 REPLIES 2
AutoCAD Electrical 2004 uses a "project" concept to
pull together a collection of one to hundreds of interrelated schematic, panel,
wiring diagram drawings together. Each project is given a name and is
represented by a small ascii text file that lists all of the different AutoCAD
drawings that are to be treated as a single project set for component
tagging, cross-referencing, wire numbering, and BOM report generation.
For these inter-drawing functions to fully work,
AutoCAD Electrical needs to be able to access the complete drawing set.
Therefore, with a PDM system, instead of checking out individual
drawing documents, you would probably want to check out a project
set.
Thanks Nate, That is what I thought. Just wanted to verify.
”Boost
