I’ve just installed AutoCAD Electrical 2015 have configured the Ribbon to my liking; changed the display order, not the actual commands per se.
That is the only “change” that I have made to the software and the Electrical portion of Acad Elect 2015 that I have made any changes to the package. I am finding that the electrical portion of Acad Elect 2015 does not work; as examples see the following;
Any thoughts as to why???
Solved by mathalekar. Go to Solution.
Hi Marc,
No problem.
Glad to hear its working.
James
1. Open up Windows File Manager and navigate to the location of the problem .exe file.
2. Click in the location bar ONCE to highlight the path and then hold CTRL and hit C to copy it.
3. Swap to ACADE and then Right Click and HOLD until the menu comes up.
4. Select Options from the menu and then click on the Files tab.
5. Select and Expand the Trusted Locations folder by clicking on the Pus sign in the box in front of it.
6. Click Add to bring up the text box for a new location.
7. Hold CTRL and hit V to paste the path copied in step 2.
8. Click Apply then OK.
9. Close and then re-start ACADE.
Regards Brad
Brad Coleman, Electrical Draftsman
