Autocad electrical 2015 Button Project task list is greyed out and when I right click on the project it`s still greyed out.
When the Task List is greyed out, it means that there is no pending changes to be made to the project.
Pending tasks are changes that you have defered to the task list rather than running them at the time.
For example, you want to change the INST/LOC of a group of components on one dwg in a project.
You go in and edit the parent component of the first block.
ACADE then asks if you wish to process other dwgs in the project to match the child components and gives you three options.
First option is to do the changes straight away - This is useful if you are only doing 1 or 2 components.
Second option is defer the changes to the task list - Use this if you are making a lot of changes in the dwg.
Third option is to skip the changes - NOT RECOMENDED as this will break the relationship between the parent and child.
After finishing those changes, you go in and select all the items in the task list and run them as well
If you defer a lot of changes some will become obsolete, so it is good practice to keep the task list as empty as possible.
I personally only use the task list when I'm doing a lot of minor changes on one dwg and don't want to wait while it processes each component change on other dwgs.
There are a multitude of commands that will give you this option so don't think it's just the one command I used as an example.
Regards Brad
Brad Coleman, Electrical Draftsman
