I have installed AutoCAD Electrical 2014, and I'd like to go back and add the manufacturer footprints and libraries that I skipped during the installation (during the installation I only added AB and ABB). So I have gone to my control panel (as if I were uninstalling the program), and run the installer in "maintenance mode". I chose "add/remove features," selected my manufacturer content and symbol libraries, and pressed next.
On the page that has feature descriptions, the installation path shows: C:\Program Files\Autodesk\AutoCAD 2014, and it cannot be changed (it is "grayed out"). After I run the installation it says I've successfully updated the product, but I cannot find any of those footprints. Where is the new manufacturer content?
Solved by TomTom111. Go to Solution.
Hello kellengross1,
I have ACE 2013, but I assume the libraries are kept up the same.
Where the footprint files are kept for 2013 are...
C:\Users\Public\Documents\Autodesk\Acade 2013\Libs\Panel
This may be a good place to check if they installed correctly.
Thomas Walls
CADMASTER TECHNOLOGIES, LLC
Would you please help to try to add/remove for another time to see if the issue still happen?
Also may I know if you install the ACE2014 directly from a DVD or from a deployment with symbol libraries shared in a server?
The Catalog database is in the following folder:
C:\Users\shouz\Documents\Acade 2014\AeData\en-US\Catalogs\default_cat.mdb
C:\Users\shouz\Documents\Acade 2014\AeData\en-US\Catalogs\footprint_lookup.mdb
And the symbol libs are in this folder:
C:\Users\Public\Documents\Autodesk\Acade 2014\Libs
C:\Users\Public\Documents\Autodesk\Acade 2014\Libs\panel
Robin Shou
Quality Assurance
AutoCAD Electrical
Acabo de instalar ace 2014 y la libreria que trae es muy escasa de modo q no puedo poner ni la bobina de un rele, ni ningun tipo de contacto abierto o cerrado. He instalado las librerias de siemens, omron y algunas mas y sigo igual. Alguien me puede ayudar por favor
recently i install ACE 2014. when i try to make my first proyect, and open the icon menu, there arent littlel icons for use. I cant to put a relay coil or a contact. Ihave installed the siemens, omron and others library but i dont find anything in the menu. somebody help me???
Hy Kellengross,
1) try to load the ribbon again
with command _ribbon
2) otherwise you can try to unload the cuiix and load the ACADe cuix again
with command_menuload
hopefully succes
regards René
