AutoCAD Electrical Forum
Autocad Electrical 2014 comand line loop
3 REPLIES 3
brandonabraun
285 Views, 3 Replies
I have been working with a problem in AutoCAD electrical 2014.  We 3 uses including myself who are experiencing a weird error when the program opens.
The program goes through the following sequence:
Customization file loaded successfully. Customization Group: ELECTRICAL
Customization file loaded successfully. Customization Group: ACAD
Customization file loaded successfully. Customization Group: AUTODESKSEEK
Customization file loaded successfully. Customization Group: MODELDOC
Customization file loaded successfully. Customization Group: CONTENTEXPLORER
Customization file loaded successfully. Customization Group: APPMANAGER
Customization file loaded successfully. Customization Group: FEATUREDAPPS
Customization file loaded successfully. Customization Group: SKETCHUPIMPORTSKP
Regenerating model.
Loading Electrical modules...
Loader application completed.
AutoCAD Electrical menu utilities
loaded.
AutoCAD Electrical menu utilities loaded.
Command: _RIBBON
Command: COMMANDLINE
Command: acenav
Command:
Command:
Command:
Command:
 After that it seems to get stuck in a loop.  It keeps issuing a null command, as if someone was holding down the enter key.  This was repeated on three separate machines.  We have checked the .lsp files and done various fixes we have seen in the forums and have had no luck in fixing this problem.
If anyone has any ideas we would appreciate the help.
3 REPLIES 3
rhesusminus
in reply to: brandonabraun
Hm... Tough one.
You say that you have checked the lisp-files... Meaning that you have some custom lisp-code?
If you remove everything custom, any changes then?
Do you run some scripts or something via the shorcut/windows command line parameters (i.e. /b Scriptsomething.scr) ?
Trond Hasse Lie
AutoCAD Electrical and EPLAN expert
Ctrl Alt El
Please select "Accept Solution" if this post answers your question. 'Likes' won't hurt either. 😉
brandonabraun
in reply to: rhesusminus
We have not done anything custom to the program.
I installed the software and booted the program up for the first time and it started with this issue.  Since then we have been looking into the reason why this loop is occurring which is why we were checking the lisp files we though that there might be something hanging in one of them.
Thanks for the reply, if you need any more information let me know.
Brandon
rhesusminus
I really have no idea whats going on then.
Are you just 3 people using AcadE, or are there others running AcadE with no problems?
If so, what are the differences between those computers? OS? Anti.virus?
Everything local install or shared data install?
Trond Hasse Lie
Ctrl Alt El
”Boost
