AutoCAD Electrical Forum
Autocad Electrical 2014 and Project Publish not finding .ctb file.
4 REPLIES 4
mpatterson
1186 Views, 4 Replies
I have an issue with trying to using the Project Publish feature in 2014. It does not load the plot style table that we have pointed to and instead outputs in color for a .pdf or what effectively is greyscale for a publish straight to a printer.
I have pointed Options > Files > Printer Support File Path > Plot Sytal Table Search Path> to a location where the file is. I also set the deafult plot style table in the publish setttings.
The same file will publish correctly when I publish project from ACE 2012. I went back and compared all the support file patchs as well as the wd.env files. I see no difference ( other than 2012 - 2014 related)
Any thoughts on how to resolve this?
Michael.
The following is what happens behind the publish script.
Command:
 Last plot's settings retrieved from C:\Users\mpatterson.PDO\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Support\user\lastplot.tmp
_.QSAVE
Command: _.ACE_SCRIPT C:/Users/mpatterson.PDO/AppData/Roaming/Autodesk/AutoCAD Electrical 2014/R19.1/enu/Support/user/_WDPLOT.SCR
Command:
Command: (COMMAND "_.SCRIPT" "C:/Users/MPATTE~1.PDO/AppData/Local/Temp/ace9FCD.scr")
_.SCRIPT
Enter script file name <C:\Dropbox\Project\31-0515 Whitney\31-0515 whitney CntrlPnl\31-0515 E-1_12.scr>: C:/Users/MPATTE~1.PDO/AppData/Local/Temp/ace9FCD.scr
Command: nil
Command: _.cmdecho
Enter new value for CMDECHO <1>: 0
Command: wd_scr_msg "========== Drawing 1 of 1 =========="
Command:
Command: wd_prnt_time_date
Searching BLOCK table for attibute "WD_TB". . .not found
Using title block attribute mapping file C:\Dropbox\Project\31-0515 Whitney\31-0515 whitney CntrlPnl\default.wdt...
Command: _.-PLOT
Detailed plot configuration? [Yes/No] <No>: _YES
Enter a layout name or [?] <Layout1>: 'wd_chk4_layoutnam_oem "Layout1"
"Layout1"
Enter an output device name or [?] <Acade - DWG To PDF_300.pc3>: C:\Dropbox\ACE\shared Printer support\Acade - DWG To PDF_300.pc3
Enter paper size or [?] <ARCH full bleed D (24.00 x 36.00 Inches)>: ?
Available media sizes.
  "ISO full bleed B5 (250.00 x 176.00 MM)"
  "ISO full bleed B5 (176.00 x 250.00 MM)"
  "ISO full bleed B4 (353.00 x 250.00 MM)"
  "ISO full bleed B4 (250.00 x 353.00 MM)"
  "ISO full bleed B3 (500.00 x 353.00 MM)"
  "ISO full bleed B3 (353.00 x 500.00 MM)"
  "ISO full bleed B2 (707.00 x 500.00 MM)"
  "ISO full bleed B2 (500.00 x 707.00 MM)"
  "ISO full bleed B1 (1000.00 x 707.00 MM)"
  "ISO full bleed B1 (707.00 x 1000.00 MM)"
  "ISO full bleed B0 (1414.00 x 1000.00 MM)"
  "ISO full bleed B0 (1000.00 x 1414.00 MM)"
  "ISO full bleed A5 (210.00 x 148.00 MM)"
  "ISO full bleed A5 (148.00 x 210.00 MM)"
  "ISO full bleed 2A0 (1189.00 x 1682.00 MM)"
  "ISO full bleed 4A0 (1682.00 x 2378.00 MM)"
  "ISO full bleed A4 (297.00 x 210.00 MM)"
  "ISO full bleed A4 (210.00 x 297.00 MM)"
  "ISO full bleed A3 (420.00 x 297.00 MM)"
  "ISO full bleed A3 (297.00 x 420.00 MM)"
  "ISO full bleed A2 (594.00 x 420.00 MM)"
  "ISO full bleed A2 (420.00 x 594.00 MM)"
  "ISO full bleed A1 (841.00 x 594.00 MM)"
  "ISO full bleed A1 (594.00 x 841.00 MM)"
  "ISO full bleed A0 (841.00 x 1189.00 MM)"
  "ARCH full bleed E1 (30.00 x 42.00 Inches)"
  "ARCH full bleed E (36.00 x 48.00 Inches)"
  "ARCH full bleed D (36.00 x 24.00 Inches)"
  "ARCH full bleed D (24.00 x 36.00 Inches)"
  "ARCH full bleed C (24.00 x 18.00 Inches)"
  "ARCH full bleed C (18.00 x 24.00 Inches)"
  "ARCH full bleed B (18.00 x 12.00 Inches)"
  "ARCH full bleed B (12.00 x 18.00 Inches)"
  "ARCH full bleed A (12.00 x 9.00 Inches)"
  "ARCH full bleed A (9.00 x 12.00 Inches)"
  "ANSI full bleed F (28.00 x 40.00 Inches)"
  "ANSI full bleed E (34.00 x 44.00 Inches)"
  "ANSI full bleed D (34.00 x 22.00 Inches)"
  "ANSI full bleed D (22.00 x 34.00 Inches)"
  "ANSI full bleed C (22.00 x 17.00 Inches)"
  "ANSI full bleed C (17.00 x 22.00 Inches)"
  "ANSI full bleed B (17.00 x 11.00 Inches)"
  "ANSI full bleed B (11.00 x 17.00 Inches)"
  "ANSI full bleed A (11.00 x 8.50 Inches)"
  "ANSI full bleed A (8.50 x 11.00 Inches)"
  "ISO expand A0 (841.00 x 1189.00 MM)"
  "ISO A0 (841.00 x 1189.00 MM)"
  "ISO expand A1 (841.00 x 594.00 MM)"
  "ISO expand A1 (594.00 x 841.00 MM)"
  "ISO A1 (841.00 x 594.00 MM)"
  "ISO A1 (594.00 x 841.00 MM)"
  "ISO expand A2 (594.00 x 420.00 MM)"
  "ISO expand A2 (420.00 x 594.00 MM)"
  "ISO A2 (594.00 x 420.00 MM)"
  "ISO A2 (420.00 x 594.00 MM)"
  "ISO expand A3 (420.00 x 297.00 MM)"
  "ISO expand A3 (297.00 x 420.00 MM)"
  "ISO A3 (420.00 x 297.00 MM)"
  "ISO A3 (297.00 x 420.00 MM)"
  "ISO expand A4 (297.00 x 210.00 MM)"
  "ISO expand A4 (210.00 x 297.00 MM)"
  "ISO A4 (297.00 x 210.00 MM)"
  "ISO A4 (210.00 x 297.00 MM)"
  "ARCH expand E1 (30.00 x 42.00 Inches)"
  "ARCH E1 (30.00 x 42.00 Inches)"
  "ARCH expand E (36.00 x 48.00 Inches)"
  "ARCH E (36.00 x 48.00 Inches)"
  "ARCH expand D (36.00 x 24.00 Inches)"
  "ARCH expand D (24.00 x 36.00 Inches)"
  "ARCH D (36.00 x 24.00 Inches)"
  "ARCH D (24.00 x 36.00 Inches)"
  "ARCH expand C (24.00 x 18.00 Inches)"
  "ARCH expand C (18.00 x 24.00 Inches)"
  "ARCH C (24.00 x 18.00 Inches)"
  "ARCH C (18.00 x 24.00 Inches)"
  "ANSI expand E (34.00 x 44.00 Inches)"
  "ANSI E (34.00 x 44.00 Inches)"
  "ANSI expand D (34.00 x 22.00 Inches)"
  "ANSI expand D (22.00 x 34.00 Inches)"
  "ANSI D (34.00 x 22.00 Inches)"
  "ANSI D (22.00 x 34.00 Inches)"
  "ANSI expand C (22.00 x 17.00 Inches)"
  "ANSI expand C (17.00 x 22.00 Inches)"
  "ANSI C (22.00 x 17.00 Inches)"
  "ANSI C (17.00 x 22.00 Inches)"
  "ANSI expand B (17.00 x 11.00 Inches)"
  "ANSI expand B (11.00 x 17.00 Inches)"
  "ANSI B (17.00 x 11.00 Inches)"
  "ANSI B (11.00 x 17.00 Inches)"
  "ANSI expand A (11.00 x 8.50 Inches)"
  "ANSI expand A (8.50 x 11.00 Inches)"
  "ANSI A (11.00 x 8.50 Inches)"
  "ANSI A (8.50 x 11.00 Inches)"
Enter paper size or [?] <ARCH full bleed D (24.00 x 36.00 Inches)>: ARCH full bleed D (24.00 x 36.00 Inches)
Enter paper units [Inches/Millimeters] <Inches>:
Enter drawing orientation [Portrait/Landscape] <Landscape>:
Plot upside down? [Yes/No] <No>: No
Enter plot area [Display/Extents/Layout/View/Window] <Extents>: _E
Enter plot scale (Plotted Inches=Drawing Units) or [Fit] <1:1>: 1.00000000
Enter plot offset (x,y) or [Center] <Center>: Centered
Plot with plot styles? [Yes/No] <Yes>: _YES
Enter plot style table name or [?] (enter . for none) <PDO-r2000_ELEC.ctb>: (c:wd_chk4_ps "C:/Dropbox/ACE/shared Printer support/Plot Styles/PDO-r2000_ELEC.ctb")
   (plot style file not found, set to ".")
*******************This is the problem that I cannot solve*********************************************
Plot with lineweights? [Yes/No] <Yes>: Yes
Scale lineweights with plot scale? [Yes/No] <Yes>: Yes
Plot paper space first? [Yes/No] <No>: _N
Hide paperspace objects? [Yes/No] <No>: 'wd_prnt_repeat_cr
Effective plotting area:  23.50 wide by 34.50 high
Effective plotting area:  23.50 wide by 34.49 high
Plotting viewport 2.
Plotting viewport 1.
Command: wd_scr_msg "========== Reopening original =========="
4 REPLIES 4
sonny3g
in reply to: mpatterson
Hmm, I have seen in other posts that some screwy things happen when using dropbox as a working directory.  I personally would not use dropbox for anything other than a storage place and for file transfers.
Scott G. Sawdy
scott.sawdy@bluecoyotecad.com
mpatterson
I have used dropbox on previous version of Autocad Electrical without issue. But I went ahead and tried it on a file that I have just NOT on Dropbox.
The same thing occurs - When using Project Right click 'Publish' - In 2014 I get the output to .pdf in color, while in 2012 with the same .pc3 and .ctb file I get printout in Black with proper lineweights.
When I go and PLOT from a file in either 2012 or 2014, from Drop Box or from my local computer, I am able to get the proper output from the .ctb file.
It appears that the line below is the issue in the 2014.
Enter plot style table name or [?] (enter . for none) : (c:wd_chk4_ps "PDO-r2000_ELEC.ctb")
I have set my 2014 wd.env file to match ( with the minor changes in references ) the one that was working in 2012.
Any other thoughts?
Michael
Icemanau
Have you tried copying the plot styles from your default 2012 location to the default 2014 location?
I know that whenever we upgrade ACADE here, we have to copy from one to another before the new ACADE can find the CTB files.
In 2014 the default path is "C:\Users\<USER NAME>\AppData\Roaming\Autodesk\AutoCAD Electrical 2014\R19.1\enu\Plotters\Plot Styles".
Here's the 2008 version for comparison "C:\Users\<USER NAME>\AppData\Roaming\Autodesk\AutoCAD Electrical 2008\R17.1\enu\Plot Styles"
I'm not sure on the 2012 path but it might be similar to the 2014 one or the 2008 one...
I originally tried to modify paths to get ACADE only use one folder for the plot styles but didn't have much luck so I just copied them all to the new versions folder.
Regards Brad
Brad Coleman, Electrical Draftsman
mpatterson
in reply to: Icemanau
I have copied the .ctb file over to the default path file without any improvement....
Does anyone know what the lines below ( specifically c:wd_chk4_ps) imply?
Enter plot style table name or [?] (enter . for none) <PDO-r2000_ELEC.ctb>: (c:wd_chk4_ps "PDO-r2000_ELEC.ctb")
I believe that in an earlier version we had found a setting to cahnge the sequence that it searched for stuff - but I thought that was catalog only and not plotter / ctb files.
any ideas?  It is getting tiresome to go back to ACE 12 to publish and then switch back to 14 to work.
”Boost
