I have done a complete uninistall/reinstall, entered correct server info, launch, it sits there for a few seconds, and stops. Task manager does not show it running.
Hi sjeickholt,
Try Adding the Flexlm_timeout Variable, it should fix the issue. (likely its timing out when its communicating with the server.)
Here is the link to the Knowledage Database for the steps:
I have also Copied them Below:
If you still cannot obtain a license, repeat the procedure; increasing the value in 1000000 microsecond increments until you are able to obtain a license from the license server
I hope this helps,
James
For a stand-alone version, you might need to delete the license files and relaunch.
%programdata%\flexnet\adsk*.data
Also, make sure you are launching with local admin rights, UAC off, and anti-virus temporarily disabled. And hopefully you are not using roaming profiles or redirected profile folders. Once you get a good launch, you should be set.
Hi James-
Thank you for your tips. I followed step by step and incremented by several 0's at the end to no avail. I wonder if there is
some kind of registry entry that I am missing. I have attempted the install more times than I can count, but always removed from
Control Panel and restarted the computer and I am still getting the same error.
In addition to the error, I get a prompt to install SP2, when I click on the 'announcement' it just sits there in Internet Explorer and goes no
further.
Thanks in advance for your help!
Sandy
Hi Sandy,
Can you post the image of the error? (the one you posted before doesn't show up).
Are you Installing a Network license or Stanadalone? (Do you know if the serial number is standalone or Network, it makes a difference)
If your not sure contact your Re-seller to have them tell you, what the license is.
I would try a few things on the next un-install /Re-install:
Log on as an admin
Disable anti-virus
Disable UAC (User Account Control)
Normally if you install on a machine without being the admin, or with anti-virus/ UAC on it can lock out file folders. (then the program won't run properly).
If you post the image of the error message I'll see what iI can do,
James
Attached is the image I am getting upon launch of AutoCAD.
I am installing a network license. The license is a network license for 5 users.
I am going to attempt another uninstall as administrator tomorrow morning, with disabling antivirus, and disabling UAC.
Are there any registry entries that could be causing havock with the uninstall/reinstall? Is SP2 essential for it to work properly?
Thanks again!!!!
Hi Sandy,
You can also Try the following:
Fatal Error while opening AutoCAD
Reset AutoCAD to defaults (see How to reset AutoCAD to defaults).
Rebuild the user profile in Windows (see Fix a corrupted user profile).
Uninstall and reinstall the .NET Framework (see How to remove and reinstall the Microsoft .NET Framework).
Uninstall and reinstall Visual C++ (see How to remove and reinstall Microsoft Visual C++ Runtime Libraries).
Clear the digital signature icons and then uninstall and reinstall the application (see FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h).
Turn off Hardware Acceleration (see Starting AutoCAD-based products without hardware video acceleration).
Update your graphics card driver. Install the latest driver from your video card manufacturer or use an AutoCAD-certified driver (see How to update your system to the latest certified video driver).
Note: A fatal error can be caused by DisplayLink Core software. If you have this installed on your system, try uninstalling it and then see if this resolves the issue. Additionally, some antivirus or desktop locking programs can cause errors in AutoCAD as they lock the system environment from working. Your antivirus may even need to be uninstalled.
If all of the above solutions fail to resolve the issue, and a full uninstall and reinstall of AutoCAD does not help (see Remove All Products from a Windows System), then you may need to reformat your hard drive and reinstall the operating system.
(This is copied from the Autodesk Knowledge base)
The only thing I can think of that would cause a regisrty error would be: An old Autodesk beta (but you installed the "real" Version.
I hope this Helps,
James
Hi Sandy,
Here was the other info (the secuity updates to look for).
James-
Thank you for all of your suggestions in trying to get Electrical 2013 to work!! This machine is going to get a re-image.
Hi Sandy,
After you re-image it let me know, just post here if you have more issues.
If you run into more issues, I'll see if I can think of anything else to fix the machine.
While I'm thinking about it, make sure that the Computer has windows XP or Windows 7 (2013 semi works on windows 8 but I would avoid it if you can).
If your stuck with Windows 8, I suggest bumping to 2014 or 2015. (they run stable on windows 8 and 8.1).
James
