Hi All,
Running ACADE 2013 on Win7 64Bit. Looks good and seems to run well so far. Just a couple of issues noticed. One is that when I right click on a dwg in the active project and go to properties and selelct "apply project defaults" it doesn't seem to work. Anyone else have this issue?
Paul
Thank you very much for reporting this issue, we have checked, it is reproducible, we have added it into our issue system, and consider the fix in future.
The workaround for this issue is to use the Settings Compare... for the drawing, and Select All the difference, Match Project for all the difference.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
That is your answer, fix in the future?????? The way you suggested takes a long time when you have a lot of drawings in the project!!!!
