I am new to AutoCAD Elec 2013. I did make thru a fundamental training class which did not really cover this. I am trying to create a bill of material on a page utilizing multiple catalog enteries on several different parts. My problem is that when I create the BOM, I get multiple listings on the BOM with the same Item number. For example, I am showing 2 seperate connectors with unique part numbers but each connector uses the same crimp pin. How can I resolve this?
Jason
Would you please help to give a sample drawing, and also a screenshot for the problem in the report, then we can know what exactly the problem it.
Robin Shou
Quality Assurance
AutoCAD Electrical
Autodesk, Inc.
attach is a picture of BOM and an attached file that it is from
Jason
Doug,
That is how I currently have it set up as. I saved my project defaults to the file and the same thing happens...
Jason
Once you have set the project properties, you need to transfer those settings to the dwgs for them to take effect.
Go to the Prject Manager, right click on a dwg and select Properties. There is an option to apply the Project Settings as well as one to show the differences between the Project Setting and the Dwg Settings (called Settings Compare).
I'm not sure if ACADE have included a function to update ALL the dwgs to the projects settings yet, so you may need to go through and update each dwgs individually.
I suggest it would be better to use the settings compare on each dwg as it will allow you to choose which settings to update. This is ideal if each dwg has different settings for the cross referencing setup.
Regards Brad
Brad Coleman, Electrical Draftsman
That was the last thing that I tried. I did see that if I used a footprint that was included in AutoCAD Electrical 2013 this does not happen, it is only happening with the footprints or schematic symbols that I have created. Is there a special tag thats needs attached for this to work correctly? When this happens on a schematic page, I used a downloaded Harting connector as the catalog item and assigned the multiple items to that. I did add attritibutes to the connector but did I miss some required ones for this? On the panel page, I copied a older non electrical drawing into the drawing for reference. When entering the footprint part onto the drawing, if it was not in catalog, I would pick an non AutoCAD electrical block and use for that part. I did not add any attributes to the block. Do I need to add the attributes and so which ones? For example, I want to enter a fuse holder and make the fuse a multilpe item of the holder. The fuse holder may be used several times on the panel.
I hope this help explains what I am trying to do.
thanks
Jason
Doug,
It sounds like I have done what you have indicated in your post. With AutoCAD Electrical 2013, can it create a BOM on a page without repeating the line item several times? or is ths a situation like you have posted in your ecadconsultant page of tips and trips for unique numbers in a BOM?
Jason
I believe I found teh thread you spoke and it apprears to resolve my issue. Will have to test when project is complete. Thanks for your help.
Jason
For this BOM bug, this may be the way to reproduce.
create small schematic and have multiple symbols with multiple parts.
WBLOCK save the several symbols/wires to a file.
Now create a new project or open an exiting and insert the INSERT WBLOCK CIRCUIT.
Now go in and CHANGE some of the subcomponents (mutliple parts) to something else.
You may have to put the parent devices on the panel layout, unsure about this part.
One TEMPORARY workaround is to make a DUMMY panel symbol and use the [+]MULTIPLE insert. It will then be picked up as a panel element even though it's already in the schematics.
