AutoCAD Electrical Forum
Autocad Electrical 2013 Fatal Error on Load
2 REPLIES 2
jtebright
522 Views, 2 Replies
When I try to open Acade 2013 I get:
Fatal Error: Unhandled Access Violation Writing 0x0000 Exception at oh
I cannot find any topics on this or how to resolve it.
Tags (1)
2 REPLIES 2
in reply to: jtebright
Hi JTEBright,
I have a few things you can try;
1. Turn the User Account Controls [UAC] off, and remove any user restrictions on file folders that ACADE Accesses
2. Try logging in as a second user on the machine (see if the new user has the same issue)
if the other user has the same issue than its not user based.
if it does work with the new user, blow away the AutoCAD Electrical 2013 file folder located in:
C:\Users\<user name>\AppData\Roaming\Autodesk\AutoCAD Electrical 2013
3. try installing the lastest SP
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240738
4. run a repair on the installation (requires the media)
5. (last resort) Re-install ACADE 2013 from working media (usb, dvd, etc)
I hope this helps,
James Alger
Solidcad
when i run AutoCAD 2014 its shows me fatal error unhandled e06d7363h exception at 0h .. 😞
”Boost
