I cannot find or get the Express menu to load in AutoCAD Electrical 2013. Some of the other users that are running ACADE 2013 have the Express menu loaded already.
How do I get this menu to load?
Insert your ACADE dvd and run the setup. Select change to adjust installed options and proceed through the setup screens until you get the screen that allows you to customise the install.
Here you select to customise the install of ACADE and you will find the install option for Express tools.
Select option/s you require and continue on. The setup should then install the express tools and any other options you selected.
Regards Brad
Brad Coleman, Electrical Draftsman
