AutoCAD Electrical Forum
AutoCAD Electrical 2013 & VBA Enabler
1 REPLY 1
1800 Views, 1 Reply
Pls Somebody has some rumors about Autocad 2013 (Electrical version on special way) & VBA Enabler tools ?? I used in the 2012 version successfully, but I removed the 2012 Autocad version, and if I try to install autocad vba enabler tools with autocad 2013 electrical version, an error message is displayed about the presence of 2012 version not installed. Thank you
1 REPLY 1
zalant
The reason you're getting the message that no 2012 products can be found is because that is the case.  You uninstalled your 2012 products, and that version of the VBA Enabler is specifically written for the 2012 AutoCAD products.  For the 2013 family of AutoCAD products, you'll need the 2013 VBA Enabler, which you can download here:
Microsoft Visual Basic for Applications Module
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12715668&linkID=9240618
Please mark this as a solution to your inquiry if it resolves the issue.
Zac Travis
”Boost
