AutoCAD Electrical General Discussion
Active Member
tlampher
Message 1 of 11 (233 Views)
AutoCAD Electrical 2011 Plotting Question
233 Views, 10 Replies
09-12-2012 07:03 AM
By default my projects always plot the layers in color.  I would like to change it so it always prints monochrome.  The only way I have found to do this is to go into my layers properties of every sheet and change it there.  That is very time consuming.  Is there a better way to do this?
Active Contributor
stefan.stamate
Message 2 of 11 (231 Views)
Re: AutoCAD Electrical 2011 Plotting Question
09-12-2012 07:35 AM in reply to: tlampher
If you right click on the project in the Project Manager select Publish and then Plot Project, select the drawings, hit OK and in the Detailed Plot Configuration mode you have a setting for Use Plot Style which you can point it to the monochrome.ctb on your PC.
Active Member
tlampher
Message 3 of 11 (221 Views)
09-12-2012 12:26 PM in reply to: tlampher
That does not work.  When I try to do that it actually won't print at all and in the command line it reads "Unknown command Adobe."  I have tried printing to all of my printers and adobe and have the same results for each.  At first I though it was my printer, but think I have that ruled out now.
Active Contributor
stefan.stamate
Message 4 of 11 (219 Views)
09-12-2012 12:33 PM in reply to: tlampher
Is it possible that your default printer is not the printer you are trying to print to? See the attached picture as well.
Active Member
tlampher
Message 5 of 11 (216 Views)
09-12-2012 12:46 PM in reply to: stefan.stamate
I think that fixed it.  Thanks for your help!  Not sure if it fixed the monochrome part because I had to get it printed and went back to my brute force method of changing all layers.
Active Member
tlampher
Message 6 of 11 (191 Views)
09-14-2012 12:10 PM in reply to: tlampher
I was wrong.  I just did another set of drawings and it did not print in monochrome even though I selected monochrome and turned on the detailed plot configuration.
Active Member
tlampher
Message 7 of 11 (187 Views)
09-14-2012 12:31 PM in reply to: stefan.stamate
See attached for all of my settings.  HELP!
Active Member
tlampher
Message 8 of 11 (185 Views)
09-14-2012 12:33 PM in reply to: tlampher
I have also tried these settings with no luck.
Active Contributor
stefan.stamate
Message 9 of 11 (173 Views)
09-14-2012 01:07 PM in reply to: tlampher
The ctb file is the one you should use and not the stb. Do you have pictures inside of your drawings?
Active Member
tlampher
Message 10 of 11 (170 Views)
09-14-2012 01:29 PM in reply to: stefan.stamate
Do you mean pictures embedded into my drawings?  No there are no pictures.  It is just a ladder diagram.
New AutoCAD Electrical Category!
The AutoCAD Electrical forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Manufacturing Community
