I have AutoCad Electrical 2010 installed on my laptop. In a recent computer update the wd.env file was inadvertently deleted. Does anyone have the default file? I had not modified it prior to the deletion.
I don't think this one is very heavily modified. I don't usually change but a couple of lines on mine. Rename from Copy of to plain wd.env.
You can also find the original WD.ENV file on your machine in the following folder:
C:\Program Files\Autodesk\Acade 2010\UserDataCache\My Documents\Acade 2010\AeData
Steve
