Does anyone know how to delete drawings from a project that is checked into Vault Pro. I tried deleting them from ACADE 2011, that leaves them in Vault, and Vault won't allow you to delete them. I tried deleting them from Vault first but again it won't allow me to delete them. The message I'm getting is: Affected Object Restriction
#######.dwg "Restrictions preventing this operation:
$/Designs/Design/E01 ####### File has version(s) with one or more parents:
#######.wdp "
I've hidden the file name. I understand that the file is in the WDP file but even if I remove it from that, Vault still won't allow me to delete the file?
can you try check out the drawing from Vault firstly, then delete it ?
Kevin Li
Thanks for your reply. I have tried that, I tried deleting it checked out, then checked in, and both times from ACADE2011 first then from Vault first, but no matter what I do Vault still say's it can't delete it due to Vaulting restrictions. Which when you look at the details it say's it's linked to other files? How do I un-link it?
