I have an annoying issue and hopefully someone can help me-
When running reports by location on all drawings I can select a location and do the report. It completes with 'no data to display'.
How can I find what is referencing the location in the project? I have looked in schematic and panel reports but cannot find any component that refers to these locations that have no objects tied to them in reports.
I am really just trying to get rid of the locations that are not being used in my drawing set.
Hi Maessell,
I can think of two things to check / try.
1. Check to make sure you are running the reports with the locations as "project wide".
(sometimes ACADE Switches the Project -wide setting to Drawing Wide when you enable the Location or installation code filtering.)
2. Try Re-building the Database (if you have no data to display it could be a corrupt database or a missing drawing thats causing the issue).
I hope this Helps,
James
