Anyone know why an AutoCAD created table, such as a BOM or table style contact cross reference will only allow a minimum 0.36 table cell hight?
I got mine down to 0.13mm cell height with text of 0.1mm high. I haven't tried to go any smaller.
To get the table format changes to take effect you have to insert a new table, it seems you cannot fully modify an inserted table.
ACADE 2011 x64
Regards
David
give it a quick try, I cant seem to get the cells under 0.36" high no matter the text hight or margin if you manually alter the properties of the table it will go down to whatever you want but generated from Acad 0.36 is the smallest I can get, must be some min. default somewhere
Once you run a rBOM eport click put on drawing then play with the text height and spacing on this dialogue I can get 0.1mm text on a bom with a row height of 0.8mm, the BOM has five rows of text per cell so this is the limiting factor. If you only have one text row per cell then I'm sure you could get lower.
Must be something with the default minimum margins, I can get the cell hight smaller playing with the settings but then the text hight is so small its hard to read....I'm looking for a text hight of .04" with a cell hight of .081" cant seem to get this combination without altering the properties of the table
that comes out at about 1mm text in a 2mm row, I can do this no problem.
I get AutoCAD message 0.081 is smaller than the minimum spacing allowed for text height 0.040, where is this minimum spacing set?
