I recently installed AutoCAD LT 2015 and I am missing Grid and Snap mode on Status Bar. I tried restoring it from drafting settings but it failed. I am only getting dotted grid ( where as I am looking for lined grid [ major and minor] by pressing F7. I tried going through some online tutorials as well but apprently nothing was helping much. Any tip or help would be appreciated.
Please refer to the attached image for reference.
Solved by jalger. Go to Solution.
Try left or right clicking on the far right icon (Three horizontal bars).
This may bring up the settings for the bottom row of icons.
If it does not show a list of the Status Toggles which includes Snap & Grid, look for a flyout menu titled Status Toggles.
Once you find them, place a check mark in front of Sanp and Grid.
This should bring them up in the display.
Then all you need to do is change the settings in grid until you get the display you wish.
Regards Brad
Brad Coleman, Electrical Draftsman
Thanks Brad for your reply.
Apprently non of the solution is working out for me.
I tried left or right clicking on the far right icon (Three horizontal bars) and there is no settings for Snap & Grid. Refer the attached image 1.
I also tried looking for menu titled " Status Toggles " but I couldn't find it anywhere. All I found was draft setting menu in which Snap and Grid are already check marked. Refer the attached image 2.
I would really appreciate your help on this.
regards,
ppatel
Ok. I will check when I get home on my ACADE 2015 and find out how to bring up the status icons for snap and grid.
However, the drafting setting in your Image 2 has what you need to get lines as the grid instead of dots.
Remove the checkmark from the first item I circled and set you spacing in the second group of circled items.
This will give you the lines your mentioned in the first post.
Regards Brad
Brad,
By removing the first iteam circled and by setting up the spacing in the second iteam circled , did not give me the lines . Also the dotted grids are disappeared now.
ppatel
I got Backlash for this once already today but here it goes...
Try changing to "ACADE & 2D Drafting and Annonations" with the ribbon. (temporarily, to see if the issue is the custom workspace)
I see from the Screenshot you are using Classic toolbars (probably imported the Classic mode).
If it was not migrated properly it will be missing some commands.
Let me know after switching it over of the commands come back.
You can also Try Opening the "Vanilla" profile to see if the options are there.
Let me know,
James
Hi Ppatel,
That's ok it tells me its not limited to one workspace (so not an import issue).
I can check if its the drawing, Post a copy of your template file (or an empty dwg) with the issue.
You can also Check to see if you have ACAD in the Partial file section in the CUI.
If you can, try opening different templates to see if it makes a difference. (ACAD.dwt, ACAD_Electricial.dwt, ACAD_Electrical_IEC.dwt, etc)
(It probably won't but I want to see if the change was somehow saved to your template, or if the template is affecting your drawing settings)
If its not showing up in any of these situatations (and Switching your Profile Didn't work) then the Install may be corrupt.
But lets check the file template first to make sure its nott he issue.
James
Hi James,
I do not have ACAD in the Partial file section in the CUI.
I also tried different templates but the result was the same.
PPatel
Hi ppatel,
Somehow I missed that this was for AutoCAD LT... (It was posted in the Electrical forum...)
Ok to change from Dots to lines you must change your Shademode to Hidden. (LT is the only AutoCAD that Requires this for the Grid to display).
If you go to the View tab change the Visual Style to "Hidden".
Or Type in "Shademode" then H for hidden.
I hope this helps,
James
Hello James,
The last suggetion didn't work either.
When I try to change the visual style from the view tab, I am getting " Image 1 " message.
and when I tried it doing from command window, its giving me " Image 2 " message. However, I was able to get lines in Model Space according to the message.
PPatel
Hi ppatel,
Well you can get grid lines in a viewport, But not in paperspace by itself. So the second error message makes sense to me.
The first error message however is interesting... How much RAM do you have installed?
The System spec for LT can be found here:
If you have the required amount (2Gb... I would be surprised if you didn't have at least 4gb)
Try cleaning out the %TEMP% location, you can clean it out one of two ways throught the windows Diskspace cleanup (buried in the control panel), or type in %temp% in windows explorer and wipeout everytthing in there (its supposed to clean itself out once it gets to big). If you are installing something, or have a log pushed out to the Temp folder you should back them up,(or Stop the install) otherwise everything is temp data that can be purged.
Other than that I'm not sure what you would need to do.
James
I know this is an old post, but all you had to do was go onto the layout and type in “grid” and you set the spacing, to be followed by typing “snap” to set the snap mode spacing. Sometimes the simplest answer is the least obvious…
